    Samsung Galaxy S II
    Back to Select settings
    How to select a ring tone
    Step 1 of 9
    Press Applications.
    Step 2 of 9
    Press Settings.
    Step 3 of 9
    Press Sound.
    Step 4 of 9
    Press Silent mode to deactivate silent mode.
    Step 5 of 9
    When the box next to the menu item is empty, silent mode is deactivated.
    Step 6 of 9
    Press Phone ringtone.
    Step 7 of 9
    Step 8 of 9
    Once you've found a ring tone you like, press OK.
    Step 9 of 9
    1. Find "Sound"
    Press Applications.
    Press Settings.
    Press Sound.
    2. Deactivate silent mode
    3. Select ring tone
    4. Return to the Home screen
