    Back to Settings & usage
    How to divert calls to COMBOX®
    To receive voice messages when you don't answer a call, you need to divert your calls to your COMBOX®.
    Step 1 of 9
    Press Phone.
    Step 2 of 9
    Press the menu icon.
    Step 3 of 9
    Press Settings.
    Step 4 of 9
    Press More settings.
    Step 5 of 9
    Press Call forwarding.
    Step 6 of 9
    Press Voice call and wait while the current settings are retrieved.
    Step 7 of 9
    Press the required divert type.
    Step 8 of 9
    Key in +4186(area code)(your phone number) and press ENABLE.
    Step 9 of 9
    1. Find "Voice call"
    Press Phone.
    Press Settings.
    2. Select divert type
    3. Return to the Home screen
