    Back to Settings & usage
    How to connect a Bluetooth device to your mobile phone
    Bluetooth is a wireless connection which you can use to transfer files between two devices or to establish a connection to other devices, such as a wireless headset or keyboard.
    Step 1 of 7
    Step 2 of 7
    Step 3 of 7
    Press Connections.
    Step 4 of 7
    Press Bluetooth.
    Step 5 of 7
    Press the indicator below "Bluetooth" until the function is activated.
    Step 6 of 7
    Press the required Bluetooth device and follow the instructions on the display to connect the Bluetooth device to your mobile phone.
    Step 7 of 7
    1. Find "Bluetooth"
    Press Connections.
    Press Bluetooth.
    2. Activate Bluetooth
    4. Return to the Home screen
