    Back to Settings & usage
    How to call COMBOX®
    You can listen to the messages left on your COMBOX®. Remember, you need to divert calls to your COMBOX®.
    Step 1 of 5
    Press Phone.
    Step 2 of 5
    Press the keypad icon, if required.
    Step 3 of 5
    Press and hold 1 to call COMBOX®.
    Step 4 of 5
    Follow the instructions from COMBOX® to check your voice messages and press the end call icon to end the call.
    Step 5 of 5
    1. Call COMBOX®
    Press Phone.
    2. Check voice messages and end call
    3. Return to the Home screen
