    Back to Settings & usage
    How to activate or deactivate use of phone lock code
    Step 1 of 13
    Step 2 of 13
    Step 3 of 13
    Step 4 of 13
    Press Iris Scanner.
    Step 5 of 13
    Press CONTINUE.
    Step 6 of 13
    Step 7 of 13
    Press CONTINUE.
    Step 8 of 13
    Follow the instructions on the display to create the phone lock code using iris scanner.
    Step 9 of 13
    Press Screen lock type.
    Step 10 of 13
    Key in the current phone lock code and press None.
    Step 11 of 13
    Press REMOVE DATA.
    Step 12 of 13
    Press REMOVE.
    Step 13 of 13
    1. Find "Lock screen and security"
    2. Create phone lock code using iris scanner
    Press Iris Scanner.
    Press CONTINUE.
    Press CONTINUE.
    Press REMOVE DATA.
    Press REMOVE.
    4. Return to the Home screen
