    How to use tethering
    You can use your mobile phone to set up an Internet connection from a laptop or desktop. Remember, you need to set up your mobile phone for Internet.
    Step 1 of 6
    Step 2 of 6
    Slide your finger downwards down the display starting from the top edge of your mobile phone.
    Step 3 of 6
    Step 4 of 6
    Press Connections.
    Step 5 of 6
    Press Mobile hotspot and tethering.
    Step 6 of 6
    Press USB tethering until the function is activated and an Internet connection from your computer via your mobile phone is automatically established. When the connection is established, you can access the Internet from your computer.
    1. Connect your mobile phone and computer
    2. Activate tethering
    Press Connections.
