Login/account box
Mobile Anleitungen
How to select network mode
You can select which network modes your mobile phone can use. Your choice determines the data speeds you can achieve.
Step 1 of 7
Step 2 of 7
Step 3 of 7
Press Connections.
Step 4 of 7
Press Mobile networks.
Step 5 of 7
Press Network mode.
Step 6 of 7
Press the required network mode.
Step 7 of 7
1. Find "Network mode"
Press Connections.
Press Network mode.
2. Select network mode
3. Return to the Home screen
