    Back to Getting started
    Guide to phone keys and sockets
    Follow these instructions for a guide on how to use the phone keys and sockets.
    Step 1 of 13
    Several functions are associated with On/Off:
    Step 2 of 13
    Press On/Off to turn your mobile phone on or off.
    Step 3 of 13
    Press On/Off to activate the screen lock.
    Step 4 of 13
    Place the tip of your finger on the fingerprint sensor to unlock your mobile phone.
    Step 5 of 13
    Several functions are associated with the Volume key:
    Step 6 of 13
    Press the upper or lower part of the Volume key to adjust the ring volume.
    Step 7 of 13
    Press the upper or lower part of the Volume key during a call to adjust the volume.
    Step 8 of 13
    Press the upper or lower part of the Volume key to silence the incoming call alert.
    Step 9 of 13
    Press the Bixby key to access the Bixby menu.
    Step 10 of 13
    Connect the charger or data cable to the socket and to a wall socket or your computer's USB port.
    Step 11 of 13
    Connect the headset to the headset socket.
    Step 12 of 13
    Point the camera lens at the back of your mobile phone at the required object to take a picture or record a video clip.
    Step 13 of 13
    Point the camera lens at the front of your mobile phone at the required object to take a picture or record a video clip.
    1. On/Off
    2. Fingerprint sensor
    3. The Volume key
    4. The Bixby key
    5. Socket
    6. Headset socket
    7. Camera lens at the back of your mobile phone
    8. Camera lens at the front of your mobile phone
