    Samsung Galaxy Note 4
    Back to Select settings
    How to select a ring tone
    Step 1 of 9
    Step 2 of 9
    Press Sound.
    Step 3 of 9
    Press Ringtones.
    Step 4 of 9
    To use one of the phone ring tones:
    Step 5 of 9
    Once you've found a ring tone you like, press Done.
    Step 6 of 9
    To use one of your own ring tones:
    Press Add.
    Step 7 of 9
    Go to the required folder.
    Step 8 of 9
    Step 9 of 9
    1. Find " Ringtones"
    Press Sound.
    Press Ringtones.
    2. Select ring tone
    Press Add.
    3. Return to the Home screen
