    Samsung Galaxy Note 4
    How to set up and use your mobile phone as a Wi-Fi hotspot
    When you use your mobile phone as a Wi-Fi hotspot, you can share your mobile phone's Internet connection with other devices via WLAN. Remember, you need to set up your mobile phone for Internet.
    Step 1 of 15
    Step 2 of 15
    Press Tethering and Mobile hotspot.
    Step 3 of 15
    Press Mobile hotspot.
    Step 4 of 15
    Press the menu icon.
    Step 5 of 15
    Press Configure hotspot.
    Step 6 of 15
    Press the field below "Network SSID" and key in the required name for the Wi-Fi hotspot.
    Step 7 of 15
    Press the drop down list below "Security".
    Step 8 of 15
    If you don't want to password protect your hotspot:
    Press Open.
    Step 9 of 15
    Press WPA2 PSK.
    Step 10 of 15
    Step 11 of 15
    Press Save.
    Step 12 of 15
    Press the indicator next to "Mobile hotspot" until the function is activated.
    Step 13 of 15
    If WLAN is activated:
    Press OK to confirm.
    Step 14 of 15
    Activate WLAN.
    Step 15 of 15
    1. Find " Configure hotspot"
    Press Open.
    Press WPA2 PSK.
    Press Save.
    3. Activate Wi-Fi hotspot
    4. Establish a connection
    Activate WLAN.
    5. Return to the Home screen
