Login/account box
Samsung Galaxy Note 3
Back to Messaging & Internet
How to write and send MMS
An MMS is a message which can contain pictures and other media files and can be sent to other mobile phones and e-mail addresses. If you can't send and receive MMS as soon as you've inserted your SIM card, you need to set up your mobile phone for MMS.
Step 1 of 15
Press Messages.
Step 2 of 15
Press the new message icon.
Step 3 of 15
Press the required contact.
Step 4 of 15
Press Enter message.
Write the text for your MMS.
Step 5 of 15
Press the attachment icon.
Insert a picture, go to 5a.
Insert a video clip, go to 5b.
Insert an audio file, go to 5c.
Step 6 of 15
Press Image.
Go to the required folder.
Step 7 of 15
Press the required picture to select it.
Step 8 of 15
Press the confirm icon.
Step 9 of 15
Press Video.
Step 10 of 15
Press the required video clip.
Step 11 of 15
Press Audio.
Step 12 of 15
Press the field next to the required audio file.
Step 13 of 15
Press Done.
Step 14 of 15
Press the send icon when you've finished your MMS.
Step 15 of 15
1. Find "Messages"
Press Messages.
2. Write MMS
3. Select the recipient
4. Write the text
5. Insert pictures, video clips and audio files
6. 5a - Insert a picture
Press Image.
7. 5b - Insert a video clip
Press Video.
8. 5c - Insert an audio file
Press Audio.
Press Done.
9. Send the MMS
10. Return to the Home screen
Customer Center
