    Samsung Galaxy Note 3 Neo
    Back to Select settings
    How to change PIN
    The PIN protects your SIM card from unauthorised use should your mobile phone get stolen. You can change your PIN to a PIN easier to remember. Remember, you need to activate use of PIN.
    Step 1 of 9
    Step 2 of 9
    Press the General tab.
    Step 3 of 9
    Press Security.
    Step 4 of 9
    Press Set up SIM card lock.
    Step 5 of 9
    Press Change SIM PIN.
    Step 6 of 9
    Key in your current PIN and press OK.
    Step 7 of 9
    Key in a new four-digit PIN and press OK.
    Step 8 of 9
    Key in the new PIN again and press OK.
    Step 9 of 9
    1. Find " Change SIM PIN"
    Press Security.
    2. Change PIN
    3. Return to the Home screen
