Login/account box
Samsung Galaxy Note 3 Neo
How to set up and use your mobile phone as a Wi-Fi hotspot
When you use your mobile phone as a Wi-Fi hotspot, you can share your mobile phone's Internet connection with other devices via WLAN. Remember, you need to set up your mobile phone for Internet.
Step 1 of 14
Step 2 of 14
Press the Connections tab.
Step 3 of 14
Press Tethering and portable hotspot.
Step 4 of 14
Press Portable Wi-Fi hotspot.
Step 5 of 14
Press Configure.
Step 6 of 14
Key in the required name for the Wi-Fi hotspot.
Press the drop down list below "Security".
Step 7 of 14
If you don't want to password protect your hotspot:
Press Open.
Step 8 of 14
Press WPA2 PSK.
Step 9 of 14
Step 10 of 14
Press Save.
Step 11 of 14
Press the indicator next to "Portable Wi-Fi hotspot" until the function is activated.
Step 12 of 14
If WLAN is activated:
Press OK to confirm.
Step 13 of 14
Activate WLAN.
Step 14 of 14
1. Find " Configure"
Press Configure.
2. Select Wi-Fi hotspot settings
Press Open.
Press WPA2 PSK.
Press Save.
3. Activate Wi-Fi hotspot
4. Establish a connection
Activate WLAN.
5. Return to the Home screen
Customer Center
