    Samsung Galaxy Note 3 Neo
    How to connect to a WLAN
    You can use WLAN as an alternative to the mobile network to connect to the Internet. Your mobile phone doesn't use mobile data when connected to a WLAN.
    Step 1 of 7
    Step 2 of 7
    Press the Connections tab.
    Step 3 of 7
    Press Wi-Fi.
    Step 4 of 7
    Press the indicator next to "Wi-Fi" until the function is activated.
    Step 5 of 7
    Press the required WLAN.
    Step 6 of 7
    Press Connect.
    Step 7 of 7
    1. Find " Wi-Fi"
    Press Wi-Fi.
    2. Activate WLAN
    3. Connect to WLAN
    Press Connect.
    4. Return to the Home screen
