    Samsung Galaxy mini
    Back to Select settings
    How to select a ring tone
    Step 1 of 7
    Press the menu icon.
    Step 2 of 7
    Press Settings.
    Step 3 of 7
    Press Sound.
    Step 4 of 7
    Press Phone ringtone.
    Step 5 of 7
    Step 6 of 7
    Once you've found a ring tone you like, press OK.
    Step 7 of 7
    1. Find "Sound"
    Press Settings.
    Press Sound.
    2. Select ring tone
    3. Return to the Home screen
