Login/account box
Mobile guides
Samsung Galaxy mini
Back to Select settings
How to activate or deactivate mobile data
You can avoid unintended data traffic by deactivating mobile data. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though mobile data is deactivated.
Step 1 of 8
Press the menu icon.
Step 2 of 8
Press Settings.
Step 3 of 8
Press Wireless and networks.
Step 4 of 8
Press Mobile networks.
Step 5 of 8
Press Use packet data to activate or deactivate mobile data.
Step 6 of 8
If you activate mobile data:
Press OK to confirm.
Step 7 of 8
When the box next to the menu item is marked, mobile data is activated.
Step 8 of 8
1. Find "Mobile networks"
Press Settings.
2. Activate or deactivate mobile data
3. Return to the Home screen
