Login/account box
Samsung Galaxy mini
Back to Select settings
How to activate or deactivate data roaming
You can avoid data traffic when abroad by deactivating data roaming. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though data roaming is deactivated.
Step 1 of 8
Press the menu icon.
Step 2 of 8
Press Settings.
Step 3 of 8
Press Wireless and networks.
Step 4 of 8
Press Mobile networks.
Step 5 of 8
Press Data roaming to activate or deactivate data roaming.
Step 6 of 8
If you activate data roaming:
Press OK to confirm.
Step 7 of 8
When the box next to the menu item is marked, data roaming is activated.
Step 8 of 8
1. Find "Mobile networks"
Press Settings.
3. Return to the Home screen
Customer Center
