    Samsung Galaxy mini
    How to set up and use your mobile phone as a WLAN hotspot
    When you use your mobile phone as a WLAN hotspot, you can share your mobile phone's Internet connection with other devices via WLAN. First you need to set up your mobile phone for Internet.
    Step 1 of 15
    Press the menu icon.
    Step 2 of 15
    Press Settings.
    Step 3 of 15
    Press Wireless and networks.
    Step 4 of 15
    Press Tethering and portable hots.
    Step 5 of 15
    Press Mobile AP settings.
    Step 6 of 15
    Press Configure mobile AP.
    Step 7 of 15
    Key in the required name.
    Step 8 of 15
    Press the drop down list below "Security".
    Step 9 of 15
    If you don't want to password protect your hotspot:
    Press Open.
    Step 10 of 15
    Press WPA2 PSK.
    Step 11 of 15
    Step 12 of 15
    Press Save.
    Step 13 of 15
    Press Mobile AP to activate WLAN hotspot.
    Step 14 of 15
    When the box next to the menu item is marked, WLAN hotspot is activated.
    Step 15 of 15
    Do the following on the device which will connect to your WLAN hotspot:
    Activate WLAN.
    Select your mobile phone on the list.
    Key in the password you selected in step 4, and a connection to your mobile phone is established.
    1. Find "Mobile AP settings"
    Press Settings.
    2. Edit settings
    3. Enter the WLAN hotspot name
    4. Select security settings
    Press Open.
    Press WPA2 PSK.
    Press Save.
    5. Activate the WLAN hotspot
    6. Establish a connection
    Activate WLAN.
