    Samsung Galaxy mini
    How to connect a Bluetooth device to your mobile phone
    Bluetooth is a wireless connection which can be used to transfer files between two devices or to establish a connection to other devices, such as a wireless headset.
    Step 1 of 9
    Press the menu icon.
    Step 2 of 9
    Press Settings.
    Step 3 of 9
    Press Wireless and networks.
    Step 4 of 9
    Press Bluetooth settings.
    Step 5 of 9
    Press Bluetooth to activate Bluetooth.
    Step 6 of 9
    When the box next to the menu item is marked, Bluetooth is activated.
    Step 7 of 9
    Press Scan devices.
    Step 8 of 9
    Your mobile phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
    Press the required Bluetooth device.
    Follow the instructions on the display to connect the Bluetooth device to your mobile phone.
    The new device is displayed on the list of paired devices.
    Step 9 of 9
    1. Find "Bluetooth settings"
    Press Settings.
    2. Activate Bluetooth
    Press Scan devices.
    4. Return to the Home screen
