Login/account box
Samsung Galaxy ALPHA
How to insert your SIM card and battery
To start using your mobile phone, you need to insert your SIM card and battery.
Step 1 of 5
Turn the back of your mobile phone towards you.
Take hold of the left side of the back cover and remove it.
Step 2 of 5
Place your SIM card as illustrated below the SIM card holder.
Step 3 of 5
Slide your SIM card into the holder.
Step 4 of 5
Place the battery in your mobile phone (top first), matching the battery contacts with the phone contacts, and press the battery into place.
Step 5 of 5
Place the back cover on your mobile phone and press it into place.
1. Remove the back cover
2. Insert your SIM card
3. Insert the battery
4. Replace the back cover
Customer Center
