    Samsung Galaxy ALPHA
    Back to Select settings
    How to activate or deactivate data roaming
    You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated. Remember, you need to activate mobile data.
    Step 1 of 4
    Slide two fingers down the display starting from the top edge of your mobile phone.
    Press and hold Mobile data.
    Step 2 of 4
    Step 3 of 4
    If you activate data roaming:
    Press OK to confirm.
    Step 4 of 4
    1. Find "Mobile data"
    3. Return to the Home screen
