    Samsung Galaxy ALPHA
    How to set up and use your mobile phone as a Wi-Fi hotspot
    When you use your mobile phone as a Wi-Fi hotspot, you can share your mobile phone's Internet connection with other devices via WLAN. Remember, you need to set up your mobile phone for Internet.
    Step 1 of 14
    Step 2 of 14
    Press Tethering and Mobile hotspot.
    Step 3 of 14
    Press Mobile hotspot.
    Step 4 of 14
    Press the menu icon.
    Step 5 of 14
    Press Configure hotspot.
    Step 6 of 14
    Key in the required name for the Wi-Fi hotspot.
    Press the drop down list below "Security".
    Step 7 of 14
    If you don't want to password protect your hotspot:
    Press Open.
    Step 8 of 14
    Press WPA2 PSK.
    Step 9 of 14
    Step 10 of 14
    Press Save.
    Step 11 of 14
    Press the indicator next to "Mobile hotspot" until the function is activated.
    Step 12 of 14
    If WLAN is activated:
    Press OK to confirm.
    Step 13 of 14
    Activate WLAN.
    Step 14 of 14
    1. Find " Configure hotspot"
    2. Select Wi-Fi hotspot settings
    Press Open.
    Press WPA2 PSK.
    Press Save.
    3. Activate Wi-Fi hotspot
    4. Establish a connection
    Activate WLAN.
    5. Return to the Home screen
