    Samsung Galaxy Ace Plus
    How to insert your SIM card and battery
    To start using your mobile phone, you need to insert your SIM card and battery.
    Step 1 of 5
    Turn the back of your mobile phone towards you.
    Take hold of the top of the back cover and remove it.
    Step 2 of 5
    Place your SIM card as illustrated next to the SIM card holder.
    Step 3 of 5
    Slide your SIM card into the SIM card holder.
    Step 4 of 5
    Place the battery in your mobile phone (bottom first), matching the battery contacts with the phone contacts, and press the battery into place.
    Step 5 of 5
    Place the back cover on your mobile phone, bottom first, and press it into place.
    1. Remove the back cover
    2. Insert your SIM card
    3. Insert the battery
    4. Replace the back cover
