    Samsung Galaxy Ace Plus
    How to connect to a WLAN
    You can use WLAN as an alternative to the mobile network to connect to the Internet. Your mobile phone doesn't use data traffic when connected to a WLAN.
    Step 1 of 9
    Press the menu icon.
    Step 2 of 9
    Press Settings.
    Step 3 of 9
    Press Wireless and network.
    Step 4 of 9
    Press Wi-Fi settings.
    Step 5 of 9
    Press Wi-Fi to activate WLAN.
    Step 6 of 9
    When the box next to the menu item is marked, WLAN is activated.
    Step 7 of 9
    Press the required network.
    Step 8 of 9
    Follow the instructions on the display to key in security settings.
    Press Connect.
    Step 9 of 9
    1. Find "Wi-Fi settings"
    Press Settings.
    2. Activate WLAN
    3. Connect to a WLAN
    Press Connect.
    4. Return to the Home screen
