    Samsung Galaxy A5 (2016)
    Back to Select settings
    How to select a ring tone
    Step 1 of 10
    Step 2 of 10
    Press Sounds and notifications.
    Step 3 of 10
    Press Ringtones and sounds.
    Step 4 of 10
    Press Ringtone.
    Step 5 of 10
    To use one of the phone ring tones:
    Step 6 of 10
    Once you've found a ring tone you like, press the Return key.
    Step 7 of 10
    To use one of your own ring tones:
    Press Add ringtone.
    Step 8 of 10
    Step 9 of 10
    Once you've found a ring tone you like, press DONE.
    Step 10 of 10
    1. Find " Ringtone"
    Press Ringtone.
    2. Select ring tone
    Press Add ringtone.
    3. Return to the Home screen
