Login/account box
Samsung Galaxy A5 (2016)
Back to Select settings
How to activate or deactivate data roaming
You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated. Remember, you need to activate mobile data.
Step 1 of 5
Step 2 of 5
Press Mobile networks.
Step 3 of 5
Step 4 of 5
If you activate the function:
Press OK.
Step 5 of 5
1. Find " Mobile networks"
Press OK.
3. Return to the Home screen
Customer Center
