    How to set up your mobile phone for MMS
    An MMS is a message which can contain pictures and other media files and can be sent to other mobile phones and e-mail addresses.
    Step 1 of 15
    Slide your finger left on the display.
    Press Settings.
    Step 2 of 15
    Press apn.
    Step 3 of 15
    Press edit apn.
    Step 4 of 15
    Press the add apn icon.
    Step 5 of 15
    Press the field below "APN name" and key in Swisscom MMS
    Step 6 of 15
    Press the field below "Profile category".
    Step 7 of 15
    Press mms.
    Step 8 of 15
    Press the field below "MMSC" and key in http://mms.natel.ch:8079
    Step 9 of 15
    Press the field below "APN" and key in event.swisscom.ch
    Step 10 of 15
    Press the field below "Auth type".
    Step 11 of 15
    Press none.
    Step 12 of 15
    Press the field below "Proxy address" and key in 192.168.210.2
    Step 13 of 15
    Press the field below "Proxy port" and key in 8080
    Step 14 of 15
    Press the confirm icon.
    Step 15 of 15
    1. Find "edit apn"
    Press Settings.
    Press apn.
    Press edit apn.
    2. Set up a new data connection
    3. Enter a data connection name
    4. Select the APN type
    Press mms.
    5. Enter the MMS server
    6. Enter the APN
    7. Select the authentication type
    Press none.
    8. Enter the IP address
    9. Enter the port number
    10. Save the data connection
    11. Return to the Home screen
