    Back to Select settings
    How to select a ring tone
    Step 1 of 6
    Slide your finger left on the display.
    Press Settings.
    Step 2 of 6
    Press ringtones+sounds.
    Step 3 of 6
    Press the field below "Ringtone".
    Step 4 of 6
    Press the play icon next to the different ring tones to listen to them.
    Step 5 of 6
    Once you've found a ring tone you like, press the required ring tone.
    Step 6 of 6
    1. Find "ringtones+sounds"
    Press Settings.
    2. Select ring tone
    3. Return to the Home screen
