    Back to Select settings
    How to personalise your phone display
    You can select various display settings, such as background image.
    Step 1 of 23
    Slide your finger left on the display.
    Press Settings.
    Step 2 of 23
    Press lock screen.
    Step 3 of 23
    Press the field below "Background".
    Step 4 of 23
    Press photo.
    Step 5 of 23
    Press change photo.
    Go to the required folder.
    Step 6 of 23
    Press the required picture.
    Drag the picture right or left to select the required section.
    Step 7 of 23
    Press the confirm icon.
    Step 8 of 23
    Press the Home key to return to the Home screen.
    Step 9 of 23
    Press Settings.
    Step 10 of 23
    Press theme.
    Step 11 of 23
    Step 12 of 23
    Press dark or light to select background colour.
    Step 13 of 23
    Press the field below "Accent colour".
    Step 14 of 23
    Press the required colour to select menu colour.
    Step 15 of 23
    Step 16 of 23
    Find the required menu item.
    Press and hold the menu item until a pop-up menu is displayed.
    Step 17 of 23
    Press pin to start.
    Step 18 of 23
    Step 19 of 23
    Press and hold the required shortcut.
    Step 20 of 23
    Press the delete icon.
    Step 21 of 23
    Step 22 of 23
    Drag the shortcut to the required position.
    Step 23 of 23
    1. Select background image for lock screen
    Press Settings.
    Press lock screen.
    Press photo.
    Press change photo.
    2. Select theme for your mobile phone's menu structure
    Press Settings.
    Press theme.
    3. Add a display shortcut
    Press pin to start.
    4. Remove a shortcut
    5. Move a shortcut
