    How to set up and use your mobile phone as a WLAN hotspot
    When you use your mobile phone as a WLAN hotspot, you can share your mobile phone's Internet connection with other devices via WLAN. Remember, first you need to set up your mobile phone for Internet.
    Step 1 of 9
    Slide your finger left on the display.
    Press Settings.
    Step 2 of 9
    Press internet sharing.
    Step 3 of 9
    Press the indicator next to "Sharing" to activate the function.
    Step 4 of 9
    Press setup.
    Step 5 of 9
    Press the field below "Broadcast name".
    Key in the required name.
    Step 6 of 9
    Press the field below "Password (minimum 8 characters)" and key in the required password.
    Step 7 of 9
    Press the confirm icon.
    Step 8 of 9
    Do the following on the device which will connect to your WLAN hotspot:
    Activate WLAN.
    Select your mobile phone on the list.
    Key in the password you selected in step 5, and a connection to your mobile phone is established.
    Step 9 of 9
    1. Find "internet sharing"
    Press Settings.
    2. Activate the WLAN hotspot
    3. Select settings
    Press setup.
    4. Enter the WLAN hotspot name
    5. Select security settings
    6. Establish a connection
    Activate WLAN.
    7. Return to the Home screen
