    How to connect to a WLAN
    You can use WLAN as an alternative to the mobile network to connect to the Internet. Your mobile phone doesn't use data traffic when connected to a WLAN.
    Step 1 of 6
    Slide your finger left on the display.
    Press Settings.
    Step 2 of 6
    Press WiFi.
    Step 3 of 6
    Press the indicator next to "WiFi networking" to activate WLAN.
    Step 4 of 6
    Press the required network.
    Step 5 of 6
    Follow the instructions on the display to key in security settings.
    Press done.
    Step 6 of 6
    1. Find "WiFi"
    Press Settings.
    Press WiFi.
    2. Activate WLAN
    3. Connect to a WLAN
    Press done.
    4. Return to the Home screen
