Login/account box
Mobile guides
How to connect a Bluetooth device to your mobile phone
Bluetooth is a wireless connection which can be used to transfer files between two devices or to establish a connection to other devices, such as a wireless headset.
Step 1 of 5
Slide your finger left on the display.
Press Settings.
Step 2 of 5
Press Bluetooth.
Step 3 of 5
Press the indicator next to "Status" to activate Bluetooth.
Step 4 of 5
Your mobile phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
Press the required Bluetooth device.
Follow the instructions on the display to connect the Bluetooth device to your mobile phone.
The new device is displayed on the list of paired devices.
Step 5 of 5
1. Find "Bluetooth"
Press Settings.
Press Bluetooth.
2. Activate Bluetooth
4. Return to the Home screen
