    Back to Settings & usage
    How to activate or deactivate use of phone lock code
    Step 1 of 8
    Press Settings.
    Step 2 of 8
    Press Touch ID & Passcode.
    Step 3 of 8
    Press Add a Fingerprint... and follow the instructions on the display to add your fingerprint.
    Step 4 of 8
    Press Continue. If you haven't previously selected a phone lock code, key in a code of your own choice twice.
    Step 5 of 8
    Press the indicator next to "iPhone Unlock" to activate or deactivate the function.
    Step 6 of 8
    Press the indicator next to "iTunes & App Store" to activate or deactivate the function.
    Step 7 of 8
    Press Turn Passcode Off and key in your phone lock code.
    Step 8 of 8
    1. Find "Touch ID & Passcode"
    Press Settings.
    2. Add fingerprint
    3. Select Touch ID settings
    4. Deactivate use of phone lock code
    5. Return to the Home screen
