    How to connect to a WLAN
    You can use WLAN as an alternative to the mobile network to connect to the Internet. Your tablet doesn't use mobile data when connected to a WLAN.
    Step 1 of 6
    Press Settings.
    Step 2 of 6
    Press Wi-Fi.
    Step 3 of 6
    Press the indicator next to "Wi-Fi" until the function is activated.
    Step 4 of 6
    When a list of WLANs within range is displayed, press the required Wi-Fi network.
    Step 5 of 6
    Follow the instructions on the display to key in the security settings, if required, and press Join.
    Step 6 of 6
    1. Find "Wi-Fi"
    Press Settings.
    Press Wi-Fi.
    2. Activate WLAN
    3. Connect to a WLAN
    4. Return to the Home screen
