    Apple iPad 2 WiFi + Cellular
    Back to Select settings
    How to suppress calls and notifications (Do Not Disturb)
    If you don't want to be disturbed by calls or notifications, you can set your tablet to silent mode for a specified period of time. You can also choose that your tablet should ring when you receive calls from certain contacts even though your tablet is in silent mode.
    Step 1 of 14
    Press Settings.
    Step 2 of 14
    Press the indicator next to "Do Not Disturb" to activate the function.
    Step 3 of 14
    Press Notifications.
    Step 4 of 14
    Press Do Not Disturb.
    Step 5 of 14
    Press the indicator next to "Scheduled" to activate the function.
    Step 6 of 14
    Press the field below "Scheduled".
    Step 7 of 14
    Press From or To.
    Step 8 of 14
    Drag the wheels to specify the period of time in which you don't want to be disturbed.
    Step 9 of 14
    Step 10 of 14
    Press Allow Calls From.
    Step 11 of 14
    Press Everyone, No One, Favourites or the required group.
    Step 12 of 14
    Step 13 of 14
    Press the indicator next to "Repeated Calls" to activate or deactivate Repeated Calls.
    Step 14 of 14
    1. Activate Do Not Disturb
    Press Settings.
    2. Set period of time
    Press From or To.
    3. Select contacts
    4. Activate or deactivate Repeated Calls
    5. Return to the Home screen
